Need help!
Rebel_Lady91
North Carolina
318 dodge magnum 5.2L V8
I have recently took my molding off the side of my truck. And i have the glue left from molding still left on my truck i tried goof off but that didnt work it just took my clear coat off. Any ideas ?? Thanks in advance
Sent from my SPH-D710BST using Tapatalk 2
Chewy
Bettendorf IA
V8
Good off took the clear off? I use 3M adhesive remover which body shops use. Kerosene and WD-40 works as well. The 3M stuff is the best I've ever used though.
Sent from my miniaturizer via tap dancing...
Rebel_Lady91
Rebel_Lady91
North Carolina
Yea i might try the WD-40 next
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Would love to hear if you got it off.
$miley
Rebel_Lady91
Rebel_Lady91
North Carolina
This is he stuff
Muddytazz
Salem, Or
2013 Ram 2500HD 4x4
Hemi baby
I removed mine last month and got from a auto paint supply store what is called an "Eraser Wheel". You chuck it up in a hand held drill and its like a big eraser taking off the glue/stickers/etc without removing the paint. You CAN remove the paint tho if your not careful and sit in one spot. I've used the eraser wheel on many rigs.
Rebel_Lady91
Rebel_Lady91
North Carolina
Thanks i will look in to it
SmokedRam
Zephyrhills, Florida
What I couldn't get off of mine with Goo Gone and a plastic scraper, wore off after a couple washes.
bmiller
I second the eraser wheel. Any left over residue can be removed with lacquer thinner on a shop rag. It's a bit harsh, but I use it all the time on urethane clears without problems.
Saleen5150
