RAM 2019 5TF GEN MULTIPLE CODE
jaortiz72
austin, texas
I was coming from highway speeds, took a ramp for a gas station stop, while making a left turn the truck stop in the curve and couldn't make it to the gas.
I scanned and got a bunch of related codes to the throttle body:
P2110,P0113,U1003,U1850,U1428,P0340,P2172,P0123,P0222,P2111,P2101.
Before that happened, while driving I got a AGS system failure but I kep running.
I started checking fuses, relays, nothing wrong
Swap the CAM sensor, the throttle body, the batter. Still the same issue the truck doesnt start, it does crank but never make it to start running.
I check the throttle body connector and got the following readings, looking the sensor harnnes from left to right: 0V,5V,5V,0V,0.09V,1.88V
So far not able to find the root cause. Please let me know if you have any ideas.
i added a brand new battery
Did you pre-charge it with a battery charger before you installed it? Just cause it's new doesn't mean the battery is any good,buy yourself one of these old school load testers and test it.
For 20 bucks it shouldn't bankrupt you,and you'll probably use it more then you think
Quality these days sucks,and just cause somethings new doesn't mean it's any good.
