Need Mud Flap Recommendations DRW with 12.50 tires
Lumpkin, Georgia
6.7l cummins
2020 3500 Night Editions Dually and I'm adding 12.50x35" tires (Toyo MTs) to my truck and would like to put Mud flaps on the back....I'm not having a lot of luck searching for what I need.....thinking like a 20" wide flap.....which company do you recommend?
Thanks,
Arena30
Hurricane, WV
6.7L Cummins
You can try Rokblokz, I have them on mine but it’s not a dually. They do make them for duallies just not for 2020’s yet. The latest they make is 2018. You may call them and see if they will fit your truck or see when they will. They are really good mudflaps I love mine.
Bamaprof
Alabama
Rek Gen makes 24 inch wide. Expensive but I ordered a front and rear set. I also run 12.5 35s on my DRW
MartyZ
Lake Orion, MI
2500 5.7l Hemi
DuraFlap
DuraFlap will make their drill-less installation full size mud flaps the width and length you need to cover your tires. If you have a rub issue, they also have pre-drilled set back bracket and flaps to fit the front and set backs for the rear2019 Dodge Dually with flares.jpg 2018 Ram 4x4 with pre-drilled 14in wide LFT for web.jpg .
