Your truck is rated to tow "up to 10,000 lbs", depending upon configuration.so I’m curious on your guys opinion on towing something this heavy. Basically it’s a toy hauler (dry weight 6400lbs) + razor (1500lbs) + food/Necessities/etc. I’m guessing weight would be around 8300-9000lbs. I plan on towing this with my 2012 ram 1500 4x4 (3.92gears). I know it says can tow up to 10,000lbs. Just wanted to get some feedback from people who have already done this.
How did the truck handle?
Was the motor screaming the whole time?
Any type of issues?
Any pointers to make tow/haul easier( besides the obvious ,bigger truck, or lighter load)
And of course I know you need a good distribution hitch to make things a little easier
Thanks for your input/feedback.
People all have differing opinions regarding which tool to use for the job.
Better to have a tow vehicle rated higher than what you are asking it to do, rather than fretting and being "on the line" regarding weights and ratings.
Tongue weight of trailer + Toy = 3/4-ton or 1-ton territory, based on the info provided...
It would depend on how the weight is loaded across the vehicle's payload and axles.So what about just toy hauler? Truck should be able to handle something like this correct (6400lbs dry). So after everything is loaded I say around 7000-7250lbs.
For example, a travel trailer with a toy hauler and the bay in the rear vs. a travel trailer with a toy hauler up front.
Ex: Rockwood sells an A-frame style pop-up with a toy hauler cage. Tongue weight of the trailer is only 300lbs, but if you load an 800lb farm ATV on the toy hauler, it brings your tongue weight closer to 1200lbs. And that would be before anything else is put in that particular camper. So before fuel or driver, you are already at or near payload, depending on other gear or equipment...
The above example was my personal struggle a few years ago with my 1500 Sierra.
On the other hand, a 30' bumper pull style or 5th wheel trailer will usually have the ATV bay rearward of the axles, and they design the weight of the RV trailer to have more weight on the tongue (or plate in terms of 5th wheel).
The concern the OP is having, aside from just general payload, will be *where* the weight is.
This is a perfect example of how a CAT Scale would be super beneficial idea once everything is loaded and ready to hit the road.
VernDiesel is much better at explaining the specifics as I've seen his posts be much more articulate and descriptive than others.
Your truck can handle around 7500# IMHO. But you need some experience and common sense.
You could do more but you are pressing your luck to be honest.
I’m usaully the guy that says yes your 1/2 ton will be fine. But you are at the edge with what you want to do.
Especially with Razor loaded an HD is a better tool for the job if you have access to one. That does not mean even with a HD you should forego the scales. It’s often only $12 & $2 per additional weigh. But some guys don’t understand its value, how to use it, are afraid they will look stupid whatever. And now days they are near every major city. CAT even has a free app with locations & gps directions.
TW isn’t a fixed thing it’s sort of a sliding scale so to speak with a WDH and WD in both your TV & TH. That is why the same TV & TT/TH can go from sketchy to stable with good setup as proven on a cat scale. The three scale setup sees what your eyes can’t.
I don’t care what the brochure TW is or what it would be without a WDH. Because much over 5k with a TT I am going to utilize a WDH per Ram’s long standing recommendation.
At 10 percent your 6,400 pound trailer will put 640 pounds on your truck axles as seen by the scales. At 15 percent 960. Lots of variables weigh into what you get down to. Without WDH and hitch tilt & spring bar load most of that weight will be put on the drive axle. In fact enough weight can use your drive axle as a fulcrum to lift some weight off the steer axle and additionally transfer it to your drive axle. This causes sketchy handling & reduces braking ability. I recently had an old timer argue that point on here but whatever.
A box front end TT towed at speed by a light truck especially with a regular hitch may need 12 to 15 percent TW so that it doesn’t sway. But I’ve also towed many TT/TH at 10 & 11 percent TW with a built in sway control WDH at 65 mph for 1,000s of miles with good stability even when passed by semi.
I’ve linked before & after threads on here but I don’t think most of you need more proof you just need to take your wet rig to a scale & work with it. If your loaded steer was lighter than the unloaded steer weight after restoring it you will quickly feel the difference; when on slick roads, during a mock emergency swerve around, when a semi passes, when trying to stop quickly. Your family, your $12, your decision. Some guys see that as cheaper and easier than trading for a new truck.. some don’t.
Before getting my HD truck I towed my 30' TT with my 13' Ram 1500 4x4 with 3.92 gears and the 8 speed. My TT weighed 8400 loaded. I bought the Equalizer 14,000/1400# unit to handle the sway. To stay within my payload of just under 1500 I tried 1000#(12%) on the hitch. It was okay until I saw it wandering going down a steep hill and ended up hitting the brake controller to straighten it out! I ended up increasing the hitch weight to 1200# (15%)and with me and the wife in the tuck we were just starting to violate our payload capacity. The next couple of times I towed down some steep hills I had no sway, even when being passed by semi trucks going down those hills!
The equalizer hitch has some good info on setting up their hitch and they talk about trailer attitude which is having the trailer close to level to about a 1 1/4" down in the front verses the back. One would have to have a level pad to do all the measuring. I went to the truck stop and weighed everything cause I wanted to know what my weights were. They were very patient with me, and I had to unhook it at one point to get all the axle weights.
I had went with the red airlift bags to level my truck and over time found that 15#s (all the time) worked to reduce my truck squat. There is definitely some debate on when to air up your load leveling bags, either before, or after you hook up your weight distribution hitch. I redid my hitch setup on a level pad with the 15# to get the correct trailer attitude. I wanted my TT to be slightly down in the front.
One thing I did notice is the front end of the truck would feel very light when I set up the weight distribution hitch first and then aired up the rear bags. That is why I went with airing the bags up 1st, cause it felt like the front of the truck was floating!
Other than that, I aired my cheap Wranglers up to the limit on the sidewall to reduce sway, but ended up going to some LT tires which significantly reduced sway. You would want to do the same by keeping you trailer tires well inflated too! With the 8 speed it had plenty of power to maintain speed except on steeper hills where I would tap the brake pedal to kick off the cruise cause it was reving up the engine trying to maintain cruising speed. That helped conserve gas mileage too! You can do like the truckers do is to speed up on the downhill part of the road to help maintain speed going up the oncoming hill, but it can be dangerous to go too fast in certain conditions when dealing with hills.
Gas mileage was about 10 on average at 62mph and would go down fast by 65 or 70. Most TT tires are rated for 65mph. One could probably put LT tires with a higher speed rating on the TT and go faster than 65 without worrying about overheating your tires.
Good luck with your towing, I went to the HD and after setting up the hitch for my HD I no longer worry about sway on hills. I still keep an eye out, probably from the time I saw the TT swaying when I had the 1500. If you get stuck in the wind you would definitely feel better having the heavier HD Truck!
