Need pictures
Scgirardi
Looking to see if anyone has this setup up and if you can send pics. Bilsteins set at 2.8. 1 inch rear coil spacer. And a 1.5 inch body lift. Thanks
J Rod
Ft. Wayne, IN
I'll have some pics for you this weekend. I already have the 1.5" body lift installed and I've got my bilsteins assembled (set at 2.8) and ready to go in. I'm hoping to get it knocked out either Friday night or Sat. morning. I'll start a new thread with before and after pics/measurements of my swap after I'm done, should be interesting to see how much difference there is in lift between the Ranchos and the Bils. Stay tuned...
S
Scgirardi
Awesome can't wait to get feedback!
Jameson
Fort Benning, GA
How was the 1.5" BL install? I was debating the 3" PA kit but damn think is almost $400 . Not sure that hassle and 1.5" is worth it. I like the $140 price of the 1.5". What's sad is I did 2.8" Bils and 1.5" BL on my 2011 lol. I just can't for the life of me remember how the bumper bracket install went hahaha. I know the body spacers were simple.
Edit- just read about all the fab work involved in running a 3" BL with my Amp Powersteps. 1.5" BL it is!!
S
Scgirardi
Are the top pictures the "before"?
S
Scgirardi
If you don't mind me asking how much did it run you to do the body lift? Or did you do it yourself.
J Rod
Ft. Wayne, IN
Install was time consuming, but easy. Like you said the spacers were a piece of cake. The rear bumper wasn't too bad, however the front bumper was a little tricky. Just make sure you have a good drill bit to drill the new upper mount holes in the frame and you only get one shot so make sure you get them right the first time. The bumpers were the only part I wished I would've had a friend over to help me with. I ended up using a rolling jack and a 4x4 and hold the front bumper up while I lined it up. It actually wasn't that bad once I figured it out. I had to take it back off to make an adjustment and was able to get it back up and bolted down in less than 10 minutes. If you have a 2 piece bumper, don't follow their instructions for removal. They made me jump through a few unecessary hoops (i.e. removing the grille).
RAMthevbied
J Rod, was your kit from zone? And did you have to PB blast the body mount bolts to loosen them up or was it an air tool job? I'll be installing mine shortly and just wanted to know what i was in for? Thanks. OP sorry for jacking your thread.
J Rod
Ft. Wayne, IN
Yes Zone, I did not use air tools but I did hit all of the bolts with PB blaster the night before. They all came out fairly easy. Oh and if you do it without air tools, don't plan on doing any heavy lifting for the next day or two. :roflsquared:
S
Scgirardi
I'm glad to hear other people have done /in the process of the setup up going for. Guys have awesome info!
RAMthevbied
Thanks for the heads up. I think i will opt for the air tool route and borrow my neighbors!
sbuko213
Arcadia, FL
6.7 HO
Hey I don't want to tell you what to do, but I'd steer clear of the body lift personally. You can fit the 35s just fine without it. My buddy had this similar setup on his 3rd gen (3" instead of 1.5"). Even though the truck looked sick, it road like crap. Hopping a curb or going over bumps it just jostled the whole truck.
S
Scgirardi
I appreciate the opinion. I head the 3 inch body will make your teeth chatter. Haven't heard anything other then the ride being a bit stiffer with the 1.5 BL.
Express SN95
Maryland
IMO the 1.5" body lift is perfect. I've had it done on 2 different Ram's (both w/5100s) and the ride quality was not affected. The only down side was that if you want tow hooks the factory ones will no longer work.
S
Scgirardi
Ehhh. I have the sport model no tow hooks to begin with! Lol
Express SN95
Maryland
Then if you don't have them, or want them (except in the custom variety), then you'll be fine. The rear exhaust tips will be able to angled up to close the gap between bumper and exhaust tips.
S
Scgirardi
The exhaust will be angles up with a 1.5 BL?
