Need some help guys
shadow11
Banned
Houston TX
Ok so I just finished putting on my drop shackles which say they are 2" but of course they are really like 1 3/4". So the before measurement with the stock shackles was 38 3/4" from the ground to the bottom of the wheel well and with the drop shackles on the measurement is 38 1/2". I'm only going to get 1/4" drop with the shackles????? I took my airbags off so they are not whats holding it up. I'm I missing something here guys???
Silverbullet08
Persona Non Grata
drive around they should settle a bit. but like i said u wont get a full 2in drop...
shadow11
shadow11
Banned
Houston TX
It only went down a 1/4" though. If I drive it around do you think it will settle a whole 1"?
glass3222
Central PA
drive around. I know mine settled about 3/4" after driving it for a few days, but I got more at first. I got 1 3/4" out of mine.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
There's nothing to flip, and I can't see them settling - its not a spring.
what kind did you get? I know the slammed1 ones had a notch in them - which determined left or right. Its been a few years since I messed with my set (I rolled on my 08 for a few months) - but I had about 1.5" drop on mine.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I can't see how they can "settle".......well, unless the angle of the shackle moves - which would kinda freak me out then.
shadow11
shadow11
Banned
Houston TX
The brand is Springtech and its down to 38" now so I guess its settling.
glass3222
Central PA
when you torque them down on a lift and the suspension is hanging down, you need to drive it to get the angle correct. Just like the front when it comes down off a lift, the tires are sitting like \ / the straighten out.
Bad Habit
Land O Lakes
Modded 4.7l
yes shackles will lay back to where they sit comfortable, think about how you installed them, str8 up and down right, atleast thats how i did mine. then after a few speed bumps and driving around they "laid back" towards the rear of the truck, like they are supposed to sit, if you want i can go out and take a pic of how mine sit now....remember dont tighten those bolts too tight they still need to move, its part of the suspension remember....
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
gotcha. I got the bolt started on mine, then put the full weight on the truck before torquing them down.
Trupiano
Registered User
6.7L CTD
Shadow don't fully torque them down until you drive it around with the full weight of the truck. They need to settle like they're saying. Think I got just about an inch and a half out of mine.
Bad Habit
Land O Lakes
Modded 4.7l
oh yeah im sure i got my 1.5", and i removed my o/l leaf so i got more....
shadow11
shadow11
Banned
Houston TX
Ok so I finished everything up and drove it a few miles and its gone done a full 1 3/4". It looks exactly how I want it now. Ill have some pics up in a couple hours, got to go give it a bath and wax.
BoBoway4
