Need to do something
ramthis9501
Oklahoma
5.2 V8
These gas prices are killing me... and its getting worse while the price just keeps going up.... so what are some things I can do to get better mileage besides the programmer (which I am currentley looking for...) I know it's a truck and I got a beast 5.2 :birgits_tiredcoffee but come on.... I'm averaging around 10 in the city. There has to be something!
bigtigga84
dela....where?
gears, efan sorta helps. i noticed an increase after i installed mine.
mitchman
SC
Take off the glasspack. You'll stop driving the way you like it to sound
badfish888
Va beach
2012 hemi express
put in neutral wen goin down hills, And NO FAT CHICKS
LB3711
Trumbull, CT
3.6L V6
go back to stock for muffler and intake to quiet it down you'll notice increase. because less heavy foot. more mods + more power and the tendency to get into it more. I doubt you'll get any better for the age of your truck.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
gears if you primarily drive in the city. They pretty much break even at hwy speeds. But it'll take a lot of miles to recoup the investment. Buy a newer/smaller truck, car or motorcycle to run errands. Fuel prices will only increase as demand increase globally.
ramthis9501
ramthis9501
Oklahoma
5.2 V8
I might just have to get a small car cause I love my truck and especially the way it sounds lol
hemifever
Apex, NC
The more mod money you spend, the longer it takes to recoup the funds in gas savings. But the more engine load you can remove, the better mpg you will have. efan, and u/d pulley will reduce engine load. Headers and exhaust. Gears help in city but worsen hwy.
Trupiano
Registered User
6.7L CTD
Remove the truck bed, passenger seat and spare tire. That'll help alot lol. It's a flipping truck man, your never gonna get awesome gas mileage! So get a small car, or drive less! = P Buying more mods won't help either.
adamwilkes14
I consider myself lucky I guess...I am getting roughly 16MPG to 17MPG stock with my 96. When is the last time your O2 sensor was changed? Those are commonly overlooked and have a service life.
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Not sure
adamwilkes14
Might wanna soak them with penetrating spray (nothing with silicon) and pull them out to see their condition. Without knowing when they were changed last, it would be a good idea to go ahead and change themout. Only really worry about the precat sensors though.
adamwilkes14
on the exhaust pipes before the cat, you should have them after the cats too, but the more important ones are the precat sensors, or "upstream"
dodgeram07
check
intake plenum gasket
cat
and for the death flash
what was the last time it had a good old tune up
you really should be geting around 15 in town
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Where do I get the O2 sensor? And where is the intake plenum gasket?
jasonw
South Dakota
3.0L Hurricane HO
O2 sensors from either a dealership, or find/order a good brand name. Bosch sensors, which are the most common found at auto parts stores, are hit or miss, quality wise.
My favorite brand so far is NGK/NTK.
ParrotHead FA
5.2 magnum
My 98 Ram was supposed to get 16 hwy and around 12 city stock from the factory, don't really know, I modified it as soon as I got it home. I do know that it has been getting 26-27 highway (at 65-70 mph) and in the 17 range in the city ever since I have had it. I put true duals with no mufflers or cats on it, added a ram air setup, use 8 mm wires, platinum +4 plugs, 4 degree advanced timing, and K&N air filter. For me at least, the sound is actually a good indicator of the fuel econony. With no mufflers at all and true straight pipes, you can really hear what the engine is doing. A loud roar indicates acelleration, and probably none to good fuel economy, when she's in the cruising 'sweet spot' those pipes will quiet down to barely a whisper as you're going down the highway. I have her engine set up to run at under 140 degrees, so even with the timing advance, I can still run 87 octane with no pinging. I tune it up every year, and usually run marvel mystery oil in my fuel. I usually seafoam it once a year too, only rather than sucking seafoam into the engine through a vacuum hose, I simply add the gallon jug of seafoam to a tank of fuel before going on a long trip. There's nothing in the stuff that would hurt engine or fuel system components, and the concentration is enough to break up any carbon or varnish formations on the injectors or pistons/valves. Oh, and it burns cleanly at this concentration and does not smoke.
I make quite a few road trips, and have found out that speed is a big factor, above 70 mph, the mileage decreases rapidly. If I maintain speeds of 85 mph and above on a trip, I estimated my mpg at around 16-18. And stop and go traffic at speeds under 40 really eat up the fuel too. I have the 26 gallon fuel tank, and if I'm doing mostly highway driving and keep her just under 70, I'll get just around 700 miles to a tank of fuel. Unfortunately, i rarely keep my foot out of it or keep from roasting the tires long enough to realize that kind of fuel economy, lol.
Dave
joshhhh
