Needing older software version
teasac
Lindale TX
I have a 2014 Laramie Limited 3500 4x4 crew cab...... my backup view is in the mirror. I purchased a wiring harness from Infotainment that would move the view to the 8.4 display. Yes it did but only if I push the cargo view while backing up.
I'm told since my system upgraded to the 18.45.xx that it cannot function like I expected. Simply said, I'm told I need to go back to a 17.xx.xx version to make this work. Infotainment wants like $200 and send them the radio to get it right????
Anyone else have this problem with a 2014 and how did you address it?? I have no idea why Ram would put the backup view in the mirror so small it doesn't help with a large screen right there that was stock.
Help always appreciated.
JoeCo
NY
Sorry I can't help with your question but I find that extremely odd as well that the backup display is in the mirror. I had a 2013 1500 sport with the 8.4 and the back up cam was displayed in the 8.4. I would have to ask if someone moved it to the mirror with an aftermarket setup but I don't understand why anyone would do that?
Hope someone here can help you get it figured out, once you do have it displayed in the 8.4 it will be much better/more usable.
chri5k
USA
Diesel
AFAIK there no way for the end user to downgrade the radio software. Infotainment bought one of the nav repair companies that was capable of doing a radio software downgrade.
18harvest
huntsville
do you have navigation?if you do going back to the oder firmware will screw that up.is your truck a auto or six speed manual transmission? If it is a auto i think you should be able to fix this with the correct miror and harnesses.if it's a manual there is a thread with others having this problem not sure if it got figured out or not.
joshhhh
