carl mcclaflin
Hi everyone. I have '18 Ram 2500 with the 6.4 4X4 and off road. I am very happy with the truck overall. I am asking all of you for some thoughts. I use K&N air intake system and decided to purchase the Pulsar module for even more uptick in power. I tow my #8500 trailer with my Ram and with the K&N it has very good power. I run 91 octane or 93 if avail. The question is when I tried to remove the connectors on the ECM as stated by Pulsar no issue. The problem is the harness would not disengage from the ecm. The harness lock popped right up but when I went to remove the actual connector it will not budge!! Normally these connectors release no problem when the locks are released. These will not!!. Still being under factory warranty I did not try and "force" the issue. Any thoughts on why the connector unlocked does not release?? My son's 2016 same set-up--no problem Mine? No. Any thoughts?? Is there something I am missing. This is NOT rocket science. But under no circumstances do I want to damage the harness or connector. That is expensive and ain't happenin'. Thank you all
