Neutral safety switch/wire/signal?
dogcar3
2012 Power Wagon
Does anybody know where I can tap into the neutral safety signal on a 2012 Ram?
dogcar3
dogcar3
2012 Power Wagon
Bump.
Hasn't anybody tapped into this for remote start? I tried searching (here and Google) to no avail. I know I can find it on the transmission, but I was hoping for a more convenient location either in the cab or more accessible under the hood.
dogcar3
dogcar3
2012 Power Wagon
OK, so I ended up just going to the large wire harness connector on the driver side of the transmission. The neutral signal wire is the yellow with dark blue strip in pin 23 (I believe?), which is the lower left if you are looking at the end of the connector so all the pin openings look like a 'T'.
