Ron B
Just purchased a 2012 Ram 1500 ST 4 door 4wd with 5.7 Hemi 6 spd auto with 60K miles. From the experts out there, what are some issues and other preventative maintenance (beyond recommended scheduled) I should be looking out for?
Aren't we able to use champion plugs instead of ngk? I just bought champions for like 30 for 16 of them, listed as direct replacement for the 30k spark plugs (copper)You have to use Mopar NGK LZFR5C–11 plugs.
Next task you have to find out if you have HOAT or OAT coolant because you are on the cut off I think. PM member H395 he just went through this. They do not mix and if you have HOAT, you are past due on this item as well as plugs and differential service. Might want to look into PEA fuel cleaners as well. And the always overlooked pcv valve, time to swap out easy job.
