New front upper control arms from Freedom offroad
2014greatwhite
Western mass
Do you if the ball joints are bolt in or press in?
crazykid1994
Damn. I’m curious about these when they release more info and pictures. I’m running zone UCA so I probably won’t switch but that’s awesome. I’m still torn between core tier 3 and the Clayton off-road Overland set with giiro joints on both ends for the rear
azcoyote
Phoenix
The thing that got me is that bundled with the Eibach Pro lift, there would now be a pretty economical 3.5 inch lift option.
crazykid1994
At 3.5” you lose a lot of down travel which is detrimental to ride quality. I’m at 2.5” of lift from my eibach kit with 1/2” strut spacer on top. I still have about 2.5-3” of down travel. Generally you want over 2” of down travel for a better ride. Or so I hear. Running the zone upper control arms definitely help with the suspension travel through the whole range so these should be great too. My only gripe of the stock and zone arms are the metal pin is embedded into the rubber so it’s one piece and under extreme off-roading can really put a lot of stress on those components.
rwhjr
maryland
That and would the CV angles be okay?
crazykid1994
Well being my front measured 3” over stock on my truck. here is a picture of my cv angles. No binding. I have not gotten the chance to flex it out to much. Going next weekend to a place called lazy springs to really play around with my truck. It really depends because sone trucks appear to be more sensitive than others. You may be fine at 3.5” with the cv angles. My only concern would really be ride quality. New upper control arms would be a must. I know when I installed my upper control arms it really made my suspension feel happier.
azcoyote
Phoenix
Are you running Eibach on Bilsteins or the Eibach Pro?
regal81455
Illinois
Anybody have these yet or will I be the guinea pig here? I'll have these and the eibach springs early next week to go along with the 5100s I have sitting on the shelf. Just installed the 1.5" Zone BL last weekend. Was thinking I'd put the spring on the 2nd notch - thoughts???
Brandam1
Otisville
Have you put these on yet? I have the bils set to 2.8 but my stock upper control arms are on there way out and looking for a new set that won’t be eaten threw.
regal81455
Illinois
Yes I have. They are well made and fit great. Highly recommended.
AzCats
Portland OR
2014 1500 CC Laramie
Do you mean the little ball mount sticking out the side as seen in this pic?
Correct the ball mount. I know the photo sometimes doesn’t reflect the product. I wanted to double check before I spend $360 for UCA. The plan is air ride upgrade with 2 inch spacers and leveling links.
