new guy needs some advice
shawnwhite78
hey fellas, just picked up a 2014 ram 4x4 quad cab and was interested in throwing a set of 35x12.5x20s on it using the factory wheels, so from what I have seen thus far is that I need some type of wheel spacer to be able to run the factory 20's and I would also need a bit of a lift and was looking at this,
2009-2013 Dodge RAM 1500 4WD 3" front 1.5" rear complete lift kit
what are your opinions on this set up, any info such as wheel spacer size, tire size, and spacer/level kit size is greatly appreciated. I don't want to throw my money away on something that will not work. thanks for all the help,
Cheers
Searay245se
BrookPark Ohio
2015 Power Wagon Laramie
I went with the 2in front level blocks from that place and I am very pleased with how it looks.From what I have read all you need to run that tire is 2in front blocks and .25 wheel spacers to push the wheel out a bit for clearance to the upper control arm.I am planning on getting the same size tires when funds allow so I have read up on this some but like everything else I could be wrong and I am sure if I am someone will point it out.
S
shawnwhite78
Thanks for the info, hopefully I can get all the info I need quickly I want to order the kit and the tires this week. So if theres any other input/suggestions/advice I would sure appreciate it.
Cheers
S
shawnwhite78
what about a 1.5 wheel spacer for the stock wheels? is it too much? is there any pcs out there of a 2.5 in level with stock 20s with 35x12.5x20s?
thanks guys for any info
argray90
NW Burbs, IL
I'm sure some guys have the set up your looking for. 1.5" spacers for the wheels sound big but I'm honestly not too familiar with spacers. I would suggest a 2.5" level not a 3" because your front end will be fully extended so as you hit a bump you'll bounce all over.
Maxtrac Suspension
Anaheim, CA
4.7L V8
Cheers
Just throwing this out there... Maxtrac offers a very affordable 2.5" strut spacer for the 09+ Ram 1500 4wd trucks. I prob wouldn't go 3" like said above as it will put too much stress on the geometry of the suspension. Here is a link to a seller that carries our products (this is just one of many but it was the quickest link I could find) hope this info helps! if you have questions or need more referrals feel free to ask away or PM me and best of luck on your research! Maxtrac 2 5" Leveling Kit 09 13 Dodge 1500 4WD 832425 | eBay
S
shawnwhite78
Ended up with the motofab 3inch front and 1.5 rear. Seems like a good product, easy install then I threw on a set of 35s with a 1/4 inch spacer. Then removed the spacer as it is NOT NEEDED to accomodate 35s with stock wheels with this leveling kit. All in all looks good and rides decent
mattman_13
How wide are the 35s that fit without a spacer?
You'd be the first I've ever heard of as it's the width of the tire not th diameter than runs it into the upper control arm. Unless factory offset has changed.
3" is gonna wear stuff in you're front end out faster. The reason why a 4" lift comes with front differential drop. Everyone seems to ask questions then go with what they want anyways around here lately.
S
shawnwhite78
35x12.5x20 amp mt there a knock off of toyo same tread design
S
shawnwhite78
here ya go
S
shawnwhite78
couple more. there is about a half inch clearance between the tire and upper control arm without a wheel spacer (enough for me), I realize that the 3 inch front spacer isn't the "popular choice"
due to extra stress on the front end but as a brand new vehicle that will only be in my possession for 3 years it should work out fine for me. I also think the motofab kit a quality piece for anyone looking imo. Dodge Leveling Kits
kidwolf908
Ahhh, ShawnWhite has the Black Express package which comes with 20x8 wheels, not 20x9. Hence his ability to clear the UCA without a spacer while running a 35x12.50. This is excellent news considering I have the same wheels and I'm hoping to go with a 4" lift and keep the same wheels.
EDIT: Just to clarify, these wheels are 20x8 with +19mm offset and 5.25" backspacing.
Saleen5150
