New Tires
jtoscano19
Mcallen, TX
I'm looking into getting new tires, because I dont like the original goodyear tires. I was wondering if I could put on those Nitto 420S tires in 305/50/20 on my stock 20's? Will they fit without any rubbing or will they just give me headaches later on?
Thanks
quietpeen
2021 TRX
Hellcat
is your truck 4x4? if so you most likely will have rubbing on the upper control arm. 1/4" would fix that
rennaissanceman
Tampa, FL
you should be fine I'm 2wd as well and my tires are 305/45/22 and they don't rub at all
quietpeen
2021 TRX
Hellcat
You also have different wheels
To the original poster, I'm petty sure the 2wd 's do have a little more clearance on the 06 to 08's. So I think you won't rub. If you had 4wd I would be saying yes you will rub
donjohnk
Syracuse
i had 305 55 20 zeons no suspension mods... no rubbing.
quietpeen
2021 TRX
Hellcat
lol.....not trying to be a ***** or anything....just don't want the original poster to think they will def. fit because they fit for somebody with a different front end or aftermarket wheels.....
donjohnk
Syracuse
well i was just replying from what you posted! SRY!:killer: lmao
JustinRam1500
