alany1199
Hey everyone, I just bought my first ram which is a 2016 2wd crew cab, big horn 5.7 hemi. All I've ever driven prior to this were 1999-2006 GM trucks. I'm looking into replacing the headlights with LED bulbs and would love some guidance on if there is any hyper flash issue once you replace the factory 3157 turn signal bulbs with LED? I know this was a common problem that GM had that was an easy fix with the purchase of an LED relay. I'd also love to know if ZDATT 9005 is compatible for the low beam, I understand fitting the bulb into the housing is tricky and makes it difficult for some bulbs to fit in the housing. On another page I also am interested in lifting the truck, I know rough country makes a kit but are there any underlying issues I should look out for when lifting these trucks? I know angles and such are important but is there any drive shaft drop or specific parts that wear once lifted I should look out for? thanks to anyone who can help answer some of these questions, I hope to learn as much as I can reading this forum!
