New Wheel Issue
Hi,
I have a question about Rockstar 2 wheels. I just purchased a set of 4 from Amazon. (Last time I use them).
I received 3 wheels correct and one wrong. After a month I finally got a replacement for the 4th.
I compared and the part number was different. After investigation, I found all of the specs are identical to the correct ones.
The only thing that was different was the bore size. 3 have 110mm bore and one has 78.1mm bore.
I know I can use the hub rings on the 3. Do you see any issues? I appreciate YOUR HELP.
Thanks MIKE
