Newbie shock & kit ?
thumperpa
Freedom, PA
2013 QCSB 2WD
Hi all just got my first ram it's a 2014 ram 1500 quad cab 2wd with Hemi and I'm going to lower it and do a few things so I had a couple questions for you seasoned owners. First if I buy the bell tech kit will I need to buy adjustable end links to have the truck set up correctly or do the relocated pieces that come with the 2/4 bell tech kit fix the rear axle geometry. Second has anyone tired Kyb adjustable shocks yet thanks ahead of time
The Q
South Texas RGV
2014 Sport R/T
The BellTech kit comes with the track bar relocation bracket. The bracket will get your thrust angel back "within" spec. But to truly get the thrust angle back to zero you'll need the adjustable Spohn track bar. If you're OCD and just have to have the wheels centered in the wheel well, then you'll need the Spohn adjustable upper and lower control arms.
thumperpa
thumperpa
Freedom, PA
2013 QCSB 2WD
Thanks
Thank you I kinda thought so but as stated just got the truck and I know people have done these set ups and could help. I'm crazy OCD so looks like more stuff to add to the cart at moe's web site
joshhhh
