Dodgeguy44
- Jan 21, 2018
- 29
- 17
- Location
- Red Deer, Alberta
- 2008
- Cummins 6.7
2010 2500 5.7 4x4. I have replaced a plugged heater core, repaired a blend door actuator, replaced the water pump, flushed the system, and refilled and bled the air out as best I could. Now I cannot keep constant heat in the cab. I took off the heater hoses at the engine and used a pump to push air out of the heater core then pinched off the lines when full and refilled the engine with coolant then took off the hose pinchers and had heat for about 10 minutes and cold again. Both heater lines are hot. So I tee'd in to the heater return line and ran a hose up above the rad, then pinched off between the tee and the engine. Started the truck and I get a small trickle of coolant out of my added hose. Seems the pump is not pushing the coolant to the heater core.
