No fob
biggdadd58
Diesel
I never gave it a thought till I was asked. Is there a way to start a 2015 3500 without the fob? Is there a place where a key, that I don't think I have , might be hidden in order to start the truck and where?
jwheeler
Washington
If you have the push button ignition, no. Why would you want a secret hidden spot to put a key?
adurm
FL
2015 RCSB
There should be a spot to plug in the fob in case the battery dies. It's a poorly designed system if not.
jwheeler
Washington
You simply press the button with the fob if the battery dies
adurm
FL
2015 RCSB
But then someone can break in and start your truck right?
After some searching, challengers can flip down the push to start button and plug the key in. Ram might have a passive rfid chip that the truck will sense even with a dead fob.
jwheeler
Washington
Not without the fob.
