F5CHASER-OKLAHOMA
2014 RAM 3500 HD w/ Aisin cab and chassis 6.7 Cummins. Doing fuel filter change late on night. It took a little longer to prime the engine (extra cranking) but finally started. Came out the next morning, key fob in ignition and no crank. Dash has no display and the odometer only displays when your press either of the following: brake, emergency flashers.
Immediately load checked the batteries and they passed. Hooked up several different brands of scanners and no communications to the truck. There is power at the OBD port to power up each scanner but no comms in any case. Removed / cleaned / greased ECM & TIPM connectors and still comms. Tried a NEW TIPM AND ECM with same results. Red wire at the ignition switch has 12v and both fuses at both batteries are good.
After a week of searching I gave up and took to the dealer. They were able to reach comms with the BCM but nothing else. As of last Friday they were going to turn it over to an electrical specialist to start tracing down wires.
Any ideas or leads are greatly appreciated so thank you in advance.
