No sound from radios
dell tait
utah
cummins
Hi. I am trying to get one of two factory radios to play. In my 2000 2500. Both turn on, scan & seek, lock on to local stations. Seam to work fine, except no sound what so ever. I have been told, there is a factory amp in dash that could be bad. If so where is it? How to test? Ect.
D
dell tait
utah
cummins
So did I pee in the pool, Jumping in here with this question? If so I'm sorry.
Chiefrider
New England
5.9 Magnum V8
I'm definitely not the knowledgeable guy about this, but I read that some of the stereos from these years are "Infinity" equipped, meaning they require an amp. Your truck may not be equipped with an amp. Just a thought.
D
dell tait
utah
cummins
thanks verry much for the re. I don't know if the after market cd that i'm replacing had an internal boost, I didn't keep it.
Bear_Gibson
Cape Girardeau, MO
5.9 magnum
I can tell you that on my 99, with the factory 6 speaker infinity system, it has an amplifier on each front 6x9. I do know that my 99 jeep xj had an amp under the back seat that powered all speakers.
Sent from my E6910 using Tapatalk
Bear_Gibson
Cape Girardeau, MO
5.9 magnum
Found this in my 2001 manual. The 2001 wiring diagrams match my 99, so I believe it should cover the 2000 also. c53906bf1bfa6661d2b9c7d2344459e3.jpgc09c776108fd9ff4b97a8414ada03fcb.jpg
D
dell tait
utah
cummins
Thanks verry much Bear. I'l see what I can do.
Steve Holtz
