No Speakers From Uconnect 8.4
tcburch
Well, folks, I have a 2019 Longhorn with the Uconnect 8.4. I park it in a two-car garage which is pretty tight due to having my other vehicle in there. I turn off the stereo whenever I'm pulling in or backing out so I can concentrate on the Park Sensors and visuals of where I'm focusing. After pulling out, I switch the unit on, it does its legal thing, and then comes on without any problems...until today...I backed out, turned it on, then everything on the screen booted up but have no sound...everything functions normally within the screen settings, just no sound...and yes, for you characters out there who are gonna ask, I checked to make sure "Mute" wasn't on...any thoughts? Thanks...
HemiLonestar
Navy Badge Coast Guard
MD
Slightly wrong section my friend.
tcburch
tcburch
Hmmmm...probably a result of my not paying attention...what thread did I post it under?
Kendall Cox
Arkansas
My 2500 occasionally does this. I have to pull the fuse to the amp to reset it.
brian42
San Diego, CA
2019 5th Gen (Sold)
HEMI 5.7L
Mine does this on occasion too. It should correct after a few key cycles (full reboots...not a turn the truck off, open the door, shut the door, start the truck restart).
You can also do a soft reboot to see if that works: push both outside buttons (volume and tune) for 30 seconds or so to reboot the system. That might work for you. It hasn't for me and mine usually clears later that day or the next.
noraa73
