Noisy wheel bearings
Dr. Righteous
Jamestown TN
Kind of disappointing that at 92K the front wheel bearings on my '14 4x4 Hemi RAM are already noisy and making a growling noise.
My 2004 Durnago Hemi did this same thing but lasted to 120k before the noise started.
Heck, not a hard fix. I'm actually looking forward to getting my shop built an putting a Rotary post life in and doing the service. For now it is rarrrrrarrarararrrrarrrarRARrrRRARARARAARRARRAR as I drive away. FCA does not "Make" the wheel bearing assys. A parts vendor does. Just like the Saginaw tilt wheel steering column issue was common to Dodge and GMC/Chevy trucks.
Does Ford and GM have the same issues with front wheel bearings??
mrq
I have already replaced the driver's side front wheel bearing on my 2wd (4wd uses the same bearing) at 116K, I may also be looking at replacing the passenger as well. I don;t think that's bad for that mileage.
Since these are unit bearings they are stupid easy to replace. I can do it in my driveway in an hour. Be a little longer for 4wd since you have to remove the CV shaft nut.
PoMansRam
East Aurora NY
Yeah, it'*****/miss with these hub assemblies/ unit bearings. I've had them go out in as little as 3-4yrs and 40-60K miles on both domestic and import brand vehicles. Some are super easy to DIY, others can require popping the whole knuckle to get access to mounting bolts, etc.
Dr. Righteous
Dr. Righteous
Jamestown TN
Sealed; not serviceable units. That is good because you can't get water and dirt in them but bad because if you can't grease and inspect them.
I can yank the hubs out of my '85 Ramchager pull the wheel bearings, inspect and grease them and KNOW I'm good to go at minimal expense.
Not so now a days with newer vehicles.
