not down shifting
raelayotte
I have a 96 ram 4x4 with the 5.2 . Its will not down shift until it drops down to 50 from doing 60. Also when just doing a steady speed it feels like it loses power.
Johnn123
Ontario
Gonna need some more info there man. Mileage? Whats been done so far? Any other symptoms? Adjusted bands? What do you mean it feels like it loses power? What does it do when it "feels" like that? I'm assuming you have an automatic.
R
raelayotte
The truck has 135000 mile. The in take been fixed 180 stat cat been cleaned out. It have a new tranny 7000 on it. When cruising down the road at a steady speed it feels like its missing but I have not had any coded.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Make sure your plug wires are routed per the Dodge TSB.
(no I don't have that handy, I think it's around here somewhere)
wingnut
Da Thumb
5.9 gas
A 96 has OBD II. So it should throw a code for a "cylinder-misfire", or a "miss", if that was the issue. Even low fuel pressure should cause that fault. A bad crank position sensor can do that. It gets more frequent as time goes on. Also stalling at low speeds, say in parking lots. A clogged cat can also cause that feeling, but I think you said cat has been cleaned? You mean "rodded-out"?
joshhhh
