swamprunner
need to know what markings to look for on nv 5600 trans to tell Im buying what i think i am
The NV5600 utilizes a cast iron case and an aluminum bellhousing. You will also see NVG embossed on the side of the cast iron case. The G56 uses an all-aluminum case construction.need to know what markings to look for on nv 5600 trans to tell Im buying what i think i am
From the last time I performed a swap like yours I needed the transmission obviously, bellhousing adapter, starter, flywheel, clutch assembly, pressure plate, flywheel and the hydraulics for the clutch.thanks fast also if going on 5.9 cummins would need an adapter plate instead of the bell housing if i remember correctly from previous research
