O2 sensor terminology
Ryd2live
Just bought a used 04 Dodge Ram 2500 4X4 5.7L. 150K miles. At some point this truck was converted to dual exhaust. There are O2 sensors fore & aft of the cat converter on both exhausts.
The check engine light is on. It was checked at local Dodge Dealer. They said computer indicated " Banks 1 & 2 upstream O2 sensors are bad". Ok, so my question is which are the "upstream" senosors & what does it mean by banks 1 & 2 ? My assumption is bank 1 is one side & bank 2 is the other side.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
First off, welcome to the forum.
Secondly, you posted in the wrong section. You need to be in the third gen section. ;)
However, I can answer your question. Upstream refers to the area of exhaust pipe BEFORE the cat(s). That is the pre-cat O2, the PCM uses those to determine the A/F ratio. The down stream O2 is what the PCM uses to determine if the cat is not doing its job, or on the later model trucks, to fine tune the A/F mixture even more.
Bank one will be the pipe for the driver's side, two will obviously be the passenger's side.
Hope this helps you.
