O2 Sensors 18 ram 5.7
18Ram150020
Shop says I need catalytic converters as well as O2 Sensors (3). No converters in stock.
Can I drive it?
Can I just change the sensors myself?
Do the converters have to be changed?
Brandon-w
Yukon
2015 Ram 1500
Do you have emissions testing?
Sent from my SM-A530W using Tapatalk
Brandon-w
Yukon
2015 Ram 1500
Brandon-w
Yukon
2015 Ram 1500
Probly save ya well over a grand. I've been running deleted cats with these and Havnt had an issue. Sometimes when it's cold it'll throw a code but that's about once a year.
chris52010trx4
ontario
Can I drive it?
Why do they think you need new cats? Do you have any noise on acceleration? In drive, park or neutral? I only ask cuz I have a noise on my driverside front only under rpm load ... it's not manifold bolts or lifters so was curious if that should be my next step ... catless would be the cheaper route.. and could just have the codes tuned out
Sent from my SM-G965W using Tapatalk
Musky Mike
NC
How many miles? Rams are not known to have faulty O2s and Cats. Cats are covered by an emission warranty, I'm not sure what it is, but it is usually around 100K.
PoMansRam
East Aurora NY
Federal emissions warranty on catalytic converters is typically 7yrs/70K miles, sometimes longer depending on the vehicle. Does this 2018 have more than 70K miles on it?
Dodge 1500 4X4
Rochester, NY
Take it to the dealer its on the state Emission Warrantee, your truck is only 2 yrs old, I think its good for 7 yrs 70,000.
slickracer
PA
2018 Big Horn Crew Cab
On a 2018? I smell a rat....
DILLIGAF
Canada
Delete all that junk off your truck :)
jws123
nj
How does a 2018 need cats already? my 2011 with 201k has orig converters lol no codes for them.
