94ram1500
is a 3:55 to 3:92 gear swap compatible with the OBD 1 ecu? 1994 ram 5.9
Yes, there is nothing stopping you from running the 3.92's in the rear axle. The SBEC PCM does not care what gears are in the axles.is a 3:55 to 3:92 gear swap compatible with the OBD 1 ecu? 1994 ram 5.9
