Obd code p00b
malsup83
Arkansas
My check engine light came on. Threward code p00b cam position sensor slow bank 1. I changed the sensor on the passenger side. Is there a second sensor that is on the driver side.
I've looked but haven't found one.
Tach_tech
5.7L HEMI
What year? Some years had issues with the oil control valve screens getting clogged or falling apart. It’s located under the intake manifold.
M
malsup83
Arkansas
It is a 14 with a 5.7 hemi. I've changed oil and cam position sensor
Tach_tech
5.7L HEMI
Oil as in oil pressure sensor? Or the oil control valve under the intake manifold?
M
malsup83
Arkansas
Just a normal oil change. Before that I changed the cam position sensor. I picked up a vvt solenoid I guess I'll tackle that tomorrow
M
malsup83
Arkansas
Oil pressure is fone. Checked all pressures and Temps. Everything is normal
