Off grid camping
homebrew
Cummins
Kind of off topic but had a question about off grid camping. We are going to be taking our new pop up trailer out for four nights. Wanted to ask what "you" would recommend for maintaining the trailer battery? We'll be gone most of the day, and only at the trailer at night. Any options that would allow me to use the fridge?
ZCR1
Swap as many lights to LED as you can. One 12 watt incandescent bulb pulls 1 amp; a LED of similar light output will pull only about .2 amps. I ordered the cheap 10 packs (yeah, made in China) from Amazon and havent had one burn out since Iinstalled them over a year ago. They put out a lot less heat too.
sbarron
Wasilla, Alaska
Does "off-the-grid" mean you'll leave the cell phones behind? ;)
xrsman
Ontario
3.0 Ecodiesel
Yes definitely swap to LED's. We went LED at our hunt camp and saved 350 watts! When you're running the camp off a generator it really helps.
I 3rd on the solar panel suggestion
homebrew
homebrew
Cummins
Offgrid'ish we are going to a country music festival. The trailer is a 2010 but has little to no use. My inlaws bought it 2 years ago and it has sat in their garage the whole time. Is it safe to run the fridge on propane for extended periods of time while we are away? And what size solar panel should I get?
smurfs_of_war
Swift Current, Saskatchewan
You can run it on propane for as long as your tank has propane in it- won't hurt a thing. You wouldn't be up in our neck of the woods heading to Craven would you? If so- don't bother with any of these suggestions because it will all be stolen/ smashed by the time you leave anyways :/
6.7CumminsDrvr
The Dude abides………
Georgia
Should be fine running the fridge off the gas, that what they were designed for. The fridge in my previous camper ran off either gas or electric.
PippinAin'tEasy
Ditto the fridge on gas. We'll be in the boonies for a week or so at a time and never had issues. Keep in mind it still runs off of the 12v system so a dead batt will mean a dead fridge (usually). Unfortunately a single 12v batt won't give you much more than 24 hrs regardless of usage thanks to the myriad parasitic draws these TT's have. Have a genny? Champion power makes a great 2500w model that runs right off of the propane.
Sent from my SAMSUNG-SGH-I547 using Tapatalk
clh1220
st Louis
Mine runs off gas or battery or electric. It doesn't need battery or electric to run off the gas.
PippinAin'tEasy
Where you getting spark for the burner? Full time pilot?
clh1220
st Louis
Push button igniter. No full time pilot light. It's in a Coleman pop up.
PippinAin'tEasy
Sweet.
Andy578
Ontario, Canada
2014 Outdoorsman
another thing you could do is just get a small generator. you wouldn't need much to recharge a battery or even run all the lights if you want. a 2000-2500 watt generator is fairly cheap but if noise is an issue there a few more expensive ones like this that claim to be very quiet but i've yet to see them running so can't support their claims
they are also very handy if like me you ever suffer power outages
clh1220
st Louis
That's a big generator to just charge a battery. I have a small 2 stroke 900. I've only used it a few time it worked for running the furnace fan.
Andy578
Ontario, Canada
2014 Outdoorsman
yeah just for the battery you can go smaller but if you wanna run everything on the generator a 2000 is usually good. i only pulled that 1 up because i see them advertised a lot and they claim to be nearly silent
clh1220
st Louis
On a popup there is not much to run on there. Unless you have a ac unit. Which if he is going off the grid I'm going to assume he doesn't have to have the ac. He will probably be hiking and cliff climbing and that cool outdoor ****. I camp different I will be the one sitting on my ass drinking a beer listening to my ryobi radio. When that wears me out I'll go inside in the ac and take a nap. Best thing IMO for the op, would be to run the fridge on gas. Maybe get a extra battery and get a decent solar charger.
PippinAin'tEasy
Totally missed it's a popup. Go drop $300 on a pair of good 6v's and they'll power that thing for a week.
homebrew
homebrew
Cummins
I ordered an 18watt 12volt solar panel with controller from Home Depot. It had good reviews and I can add additional panels if I ever need more juice.
