Oil on cross member after oil change
Airborne63
So after the dealer did an oil change, got that thrown in when I purchased the truck, I noticed oil on the front cross member. I haven't looked under the hod yet but what could this oil be from that far forward? Was the mechanic that messy when putting oil back in the motor?
clh1220
st Louis
Oil filter ,if you SPILL any taking the filter off, it will drip for days. Depending on the incline it's parked.
Dubstep Shep
Houston
2014 R/T
That's seriously the worst location for the filter. I really want to get a relocation kit...
Airborne63
Airborne63
Thanks for the info. Guess the first oil change they did a better job of keeping that area clean.
BogsRam14
NJ
Yup as others said the oil filter. I use a large zip lock bag over the filter when removing. It helps keep the mess to a minimal.
dhay13
make sure your filter is tight. between my truck and my wifes jeep 4 out of 5 oil changes the dealer left the filter loose:3681700201_eef6d1e2
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
I get so angry every oil change! who ever decided that the oil filter should go there should be shot, dragged, shot again then made to watch back to back episodes of King of Queens
clh1220
st Louis
A engineer decided to put that filter there. Because they have all this book smarts in there head, they had no room left for common sense. And what's wrong with king and queens.
Dubstep Shep
Houston
2014 R/T
Hey now, I'm an engineer and I can tell you that's a bad location for that filter lol.
What probably happened is this:
The engine design is probably controlled by one group that has certain design requirements given to them by another group. These design requirements are based on the line of vehicles that the manufacturer is offering. They're given information like how large the external dimensions can be and things like that. They likely use the same design year after year and make small changes only.
The chassis design is controlled by another group that also has certain design requirements. They also have certain requirements they are given by another group. They take the engine designs and make them fit in the vehicle. Usually this means designing things like engine mounts. They don't get to make changes to the engine.
The chassis group may notice the poor location of the oil filter on the trucks and complain to the engine group. The engine group looks into it and comes up with a design that will fix the issue. They both meet with another group that's in charge of manufacturing costs, and that group shoots the idea down because it would cost too much money and disrupt the manufacturing process. They say they don't want to make a different engine for the trucks alone.
Welcome to Engineering.
clh1220
st Louis
Well I like my idea better. No common sense.LOL. Here is what I think a engineer does. Hmmmmm if I put this bolt here, they will have to take all this **** off to get to it. Hehehe
12TrueSport
San Diego, CA
2015 True Blue Pearl Sport
HEMI 5.7
For those that change their own, I suggest a cut 2 liter bottle with some hose on the end going to your tub. the filter drops in the 2 liter bottle and the oil drains to the tub. Not ideal but it's much cleaner.
Fatboy1989
