Oil Pan Replacement
TrekLawler
Magnum 5.2
Hello Everyone,
New to the forum, appreciate the opportunity to post.
I have a 2013 RAM Longhorn with the 5.7 and getting ready to go through the engine and install the new cam with MDS delete kit as well as headers, new oil pump, etc. The oil pan does have quite a bit of rust on it and I thought since I was digging into this project and will have to remove the pan anyway to replace the oil pump I would look into a new pan. Since I do live in the Midwest and rust belt where a lot of salt is used in the winter time I'm leery about installed another stamped steel pan and was looking into aluminum alternatives. Holley sells one that is for gen III hemi engine swaps
Has anyone ever done or used one of these with success?
thank in advance
Trek Lawler
Kansas City, MO.
Hello Everyone,
thank in advance
Trek Lawler
Kansas City, MO.
It only holds 6.2 quarts,the stock pan holds 7 quarts.Keep us updated on it if you spring for one. Your factory pan did make it 12 years,if you get another 12 years out of a stock replacement pan,that'd probably be the end of the trucks life expectancy
T
TrekLawler
Magnum 5.2
very good point on the age. never really thought of it that way.
thanks
Buy a new or good used Pan..
then find a local Powder Coating Shop, one that the Hot Rodders use.
They will sand blast it & powder coat it will any color & texture that you could possibly care for.
But the cost may not be worth it
My Harley Trike has powder coated gas tanks
My Rams Nerf Bars are Powder Coated, as is the Sign Rack
jws123
nj
By the time a new pan rots out the rest of your truck will probably go first new vehicles are made out of paper having rust issues on my 2014 already.
