Oil Temps-Not hot enough?
James OBrien
St. Louis
5.7 Hermi
I originally posted this in the general 4th gen forum, but it probably belongs here...
I've recently completed quite a few mods, including a 180 degree thermostat w/fan delete, mild cam (HL .5) from Jay Greene, LT no cat headers, and switched to Redline 5w30 last week.
Trouble is, and I'm not sure it's a problem which is why I'm asking, the oil temp doesn't get above 212 degrees anymore! I'm hovering in the 200-208 range, with my normal 45 mile daily commute on a mix of highway and back roads. Is it harmful to not boil off the water that condensates in your oil over time? I'm sure with some spirited driving and hotter days I'll get it over, just pondering here and seeing what input you may have.
Oil pressure has been steady at 50 @ idle and 55-60 depending on how much throttle during normal driving (normally 55). Coolant temps run in the 190-195 range, transmission about the same with spikes up to over 200.
Hemi395
Cape Cod MA
You should be fine, Redline 5w30 runs cooler than most oils anyway. I had a UOA run on Redline 5w30 I used over the winter a couple years ago and the oil temp never broke 190. I thought for sure they were going to say it had moisture in the oil but it came back with none.
I think as long as you get the oil up to 180+ it gets hot enough to get moisture out of the oil so you should be good.
James OBrien
James OBrien
St. Louis
5.7 Hermi
Great, thanks for the quick reply! Good to know there are others out there who have experienced the same thing and have some evidence it won't be a problem.
U&A
2016 3500 SRW
6.4 HEMI
190-200 and you have no worries.
Water will still cook off at those temperatures
Sent while firmly grasping my redline lubed RAM [emoji231]
Steve58
