Oil weight poll, trying find a link
Which weight oil are you using?
  • 5w20
    Votes: 27 37.5%
  • 5w30
    Votes: 36 50.0%
  • Other
    Votes: 9 12.5%
  • Total voters
    72
sottis
151000
6000-8000
Mobil 1
no lifter failures
no tick
Harley Harrold
USAF Ret. 36+ years service
Navy Badge Air Force Firefighter
Mississippi
5.7L HEMI
2007 QUAD CAB 1500, RWD, 5.7L HEMI
MDS turned off thru tune
AMSOIL 5W30XL Synthetic engine oil
Oil changed every 5,000 miles or 1 year, whichever occurs first
Oil filter: Mobil 1 Synthetic Extended Mileage
Current mileage is 88,500 miles
No problems other than slight tick until warmed up.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Which oil weights are you using ?
5qts-5w30, 2qts-10w30
please also answer the following:
Model year?
Miles?
18,100
Miles between changes?
7-8k
Conventional or synthetic?
full synthetic
Any lifter failures?
no
Any abnormal tick?
no, nothing on cold or hot start after using 2 qts of 10w30. I had a cold start tick with the factory fill when the truck sat for more than 3/4 days like a long weekend. Definitely a lifter tick with factory fill with bleed down over periods of time with the 5w20 factory blend.
doubleM
Omaha
Model year? 2008
Miles?111,000
Miles between changes? 5000
Conventional or synthetic? QSUD with RP filter
Any lifter failures? no
Any abnormal tick?
no
eddie046
2017 5.7 Hemi
Mobil 1 5W20 with Mobil 1 filter every 5K miles
40K miles
No ticks or any other noises thus far.
10 Break
Dayton, OH
Crashing your 4th Gen thread.....
Model year? 2007 4.7
Miles? 197,500
Miles between changes? 5000-6000
Conventional or synthetic? Mobil 1 synthetic / Wix XP filter
Any lifter failures? No
Any abnormal tick? No
Ocelot
5.7 Non-Etorque
2011 4.7 Flex Fuel
5W-30 ( Used 5W-20 first 40,000 Miles or so)
61,000 Miles
No noise
Always Full synthetic various brands....Most often Penzzoil PUP, but also Castrol Edge, Mobil One
KLook
Harrison, Tenn
10,000 or less until last change, at 8000
Full Syn
No
No
Kevin
My last one, a 2012 4.6 4x4 failed at about 56,000. The ticking came on gradually but the real deal was when the lower end went. The dealer said they were replacing the upper valve train and I knew it was not the valves, I traded before they did the work. I did not know I could extend the warranty once they opened the motor up. I would have kept it with a guarantee as I only had 4000 left on the original warranty.
boblonben
Model year?
Miles?
Any abnormal tick?
2017 5.7L RAM Sport Crew Cab
11745
5K
Synthetic - Mobil 1 Extended Performance 5W-20
No lifer problems
No tick of any kind
boblonben
Model year?
Miles?
Any abnormal tick?
11745
5K
No lifer problems
No tick of any kind
boblonben
Model year?
Miles?
Any abnormal tick?
11745
5K
No lifer problems
No tick of any kind
MICHAEL ZIMMER
Elgin, Illinois
2016 Ram 1500 5.7 Liter
Schaeffers 9000 5-20w oil, WIX/XP filter, 7500 miles.
I had a 2007 5.7liter and ran heavier oil than specified (thinking it was better for the engine) and that motor developed a tick at 60,000 miles. I replaced lifters and pushrods (2 pushrods were shorter) and after that I always ran the specified oil weight NEVER HEAVIER !!!
Jim Bowker
Saugus, Ma
Model year? 2017
Miles? ~20,000
Miles between changes? Whenever the EVIC tells me
Conventional or synthetic? 5w20, so synthetic
Lizzy B
Houma,La.
4.7L
Mi. 110,000
Conventional
Change every 3000 or so
No tics
No lifter problems
5W-30
tomb
ontario canada
2012 bighorn-cherry red
exact same oil and filter and intervals---no problems
pup oil-mobil 1 filter but my intervals are every 9 months -with only 4000kilometers and runs as new
18ram18
st louis
I do a tire rotation at the same time as OC. so the 6500 to 7000 interval works well
JB1
Houston, Texas
Model year = 2017
Miles = 16K miles
Miles between changes = every 6 months
Conventional or synthetic = see pic
Any lifter failures = none
Any abnormal tick= none
Here’s what I use
Arturo Rojas
