Oil weight poll, trying find a link
Which weight oil are you using?
  • 5w20
    Votes: 27 37.5%
  • 5w30
    Votes: 36 50.0%
  • Other
    Votes: 9 12.5%
  • Total voters
    72
Cshaffer126
Virgnia
Which oil weights are you using ?
please also answer the following:
Model year?
Miles?
Miles between changes?
Conventional or synthetic?
Any lifter failures?
Any abnormal tick?
Cshaffer126
Cshaffer126
Virgnia
My responses
Model year?
Miles?
11,100
5,000
Conventional or synthetic? Synthetic
Failed at 11k miles (hard tick present) no CEL.
Any abnormal tick?
Still a slight tick when truck idles with warm oil after sitting.
heefageLA
Vidalia, LA
05, 14, 17, 20, 23
2017 5.7L
~37,000 miles
~5,000-6,000 OCI
Redline 5w-30 w/ Wix XP filter
No failures.
Only ticks for about 2-3 seconds when I cold start and move the truck very short distances to blow off the driveway or move it to wash the truck, etc... And thats only when I start the truck for a second time. If the truck doesnt get a chance to heat up all the way, I get a tick on the second cold start.
Something to add, I turn off my MDS religiously since I bought the truck. I had about 25k on it when I got it.
A failure at only 11,000 miles is scary as hell to me! Did the dealership treat you right?
Cshaffer126
Cshaffer126
Virgnia
2017 5.7L
~37,000 miles
~5,000-6,000 OCI
No failures.
EDIT: a failure at only 11,000 miles is scary as hell to me! Did the dealership treat you right?
They took good care of me. However, I have lost a lot of confidence in the platform but I am also not super convinced the lifters actually failed, some bearings felt slightly tougher than others, maybe a little bit of uneven wear. The thing that boggles my mind is that the hard ticking on cold starts went away...
18ram18
st louis
8250 mi
6500-7000 OCI (first @ 1250)
PUP synthetic / mobile 1
no failures
Burla
2010 Hemi Reg Cab 4x4
All I can say about oil type and cam/lifters is I kinda of doubt there is an argument at all for thin low anti wear/extreme pressure (aw/ep) additive oil being better then the opposite. I'd say the opposite does at least have an argument, but there simply wont be a lot of data to make serious conclusions. Clearly some oils kill ticks left behind with the low additive gf-5 20 weights, that part is a straight fact at this point.
Cshaffer126
Cshaffer126
Virgnia
Even after my complete lifter replacement there is still a slight tick (sounds like one lifter is louder than the others) I’m really interested to try redline for that moly content but I also don’t want to quiet a problem that will develop into a failure.
Burla
I can't help you there, my tick is gone and so is many others. No cams needed at this point knock wood.
Burla
Update syn thread however it works out.
kurek
Northwest
Model year? 2015 1500 (Hemi 5.7 w/ MDS)
Miles? 31000
Miles between changes? ~6K-9K
Any lifter failures? No
Any abnormal tick? No
5W20 as specified by the manufacturer. No problems, no ticks.
VB712
Maxi_built
Va Beach
You run redline 5-30 and a wix xp right?
huntergreen
Marine Corps Navy Badge
What's the mileage on your truck now ? Tks
huntergreen
5-20 pup. 6 month/ 6000 mile, which ever occurs firsti, oci.
2016 big horn hemi.
29000 miles.
Dusty
Rochester, New York
Model year?
Miles?
Any abnormal tick?
Current: 2019 Ram 1500 @ 24500 miles
Oil change: 1st @ 9543 miles, 2nd @ 9861 miles
Oil type: synthetic
Lifter failures: none
Abnormal tick: none
PREVIOUSLY OWNED: 2010 & 2014 Ram 1500s w/5.7
Traded at 107000 and 93000 miles
Average oil change was between 9300 10000 miles
Used semi-synthetic oil in 2010, and semi- and full synthetic in 2014. Used Mopar or Fram oil filters only.
Did not experience lifter failures on either vehicle nor any abnormal ticking sounds.
Regards,
Dusty
2019 Ram DT 1500 Silver Billet Laramie, Quad Cab, 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, 18 inch wheels. Build date: 17 April 2018. Now at 024522 miles.
Matches
Cheap synthetic
40k
5k between
No ticks or abnormal noises
No lifter problems
