Oil Weight
Tulecreeper
Or, as my old man from Kentucky used to say, "Orl waite."
The manual for my 2023 2500 calls for 0w-40. Is that correct? Is that what they put in at the factory? I've seen 5w-XX before, but never 0w-anything.
Dean2
Near Edmonton
Thanks, I figured I was reading it right. It just kind of surprised me. Where have you found that weight? I was in WM last week and thought I'd go look, but none of the brands had that.
I have the dealer change the oil using Penzoil Platinum full synthetic, which is what comes in the truck. It costs within 20 bucks of doing it myself.
Jane S
Read the manual - it should say wich MS the oil should meet.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
As stated above some parts stores have it but I always got mine off of Amazon. Only a hand full of oils meet the requirements for the 6.4 Hemi so I always stuck with Penzoil. The cams/roller lifters on these used to be really picky so I highly suggest using what the manual asks for.
tron67j
Maryland
There are a zillion threads in 4th and 5th gen on this subject, highly recommend reading a couple. Really knowledgeable people giving some good information.
dhay13
I used the Mobil 1 0-W40 I got from Auto Zone just last week. Prior to that it always went to the dealer but just didn't have time this time around.
Jane S
Yes, it does. MS-12633 is now MS-A0921.
I searched and do not see that M1 0w40 meets either of those.
PUP meets both.
Dean2
Near Edmonton
Mobile 1 5-20 meets the spec for the 5.7 but when I looked a few months ago their 0-40 idid not meet the spec for the 6.4. I would not be suprised if it still doesn't. That said it wouldn't stop me from using it if I couldn't find Penzoil.
06 Dodge
Forest Grove, Oregon
6.7L CTD
Below is what owners manual has to say about what oil to use in the 6.4 Hemi, too me it looks like any 0w40 synthetic oil that is API rated can be used thus Tulecreeper can use Mobil One 0w40 oil if he likes...
"We recommend using Mopar® API Certified SAE 0W-40 Full Synthetic Engine Oil
which meets the requirements of the manufacturer Material Standard
MS-A0921. Equivalent full synthetic SAE 0W-40 engine oil can be used but must
have the API Donut trademark"
Jane S
Earl, that you?
dhay13
M1 is the only 0-W40 our local chain stores carry. Could have ordered it but am comfortable with M1
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
I think Pennzoil Ultra Platinum is the only oil that meets MS-A0921. And you'll basically never find it on shelves anywhere. But, it's what dealers use on the 6.4's. You can get quarts of it from your dealer, though it'll be labeled Mopar SRT.
That being said you are not required to run oil that is MS-A0921 certified. It only has to be API certified.
huntergreen
Marine Corps Navy Badge
In the 4th gen section there is a lengthy oil thread. Plenty of info. I’d read hemiman posts. Same truck but 4th gen.
Tulecreeper
Tulecreeper
PUP meets both.
Let me rephrase - Mobil 1 is suitable for MS-12633, 6.4L Hemi use. https://buyoil.com/product/mobil-mob1-0w-40bx/
