Oil Weight
Willie Mosher
Las Vegas Nevada
6.4 gas
Yes, back in the Old days ( 60s to 80s) pennzoil an Quaker State
Was pretty much wax . paraffin base Oils, but they long gone now Arnold Palmer granddaddy tractor. Had not running in years. New kids running show now. An one or two maybe educated.
Wyo72
Wyoming
Ahhh nothing like an oil thread to get people at each others throats. LOL
OP- yep 0W-40 is correct. I've never had a vehicle that used that weight either until I bought my ram.
quickster2
SE Michigan
2015 Ram Laramie 2500 4 X 4
6.4L
Manufacturers also contract with oil suppliers for whoever gives them the best volume deal. It's why every so many years a manufacturer will switch from whatever they are using to a different brand. I wouldn't read in to brand all that much. Or even oil weight.
You also have to take in to consideration that manufacturers are pulling every trick in the book to scrounge up every last fraction of a percent of fuel efficiency. That means moving to lighter weight oils. Just look at the Pentastar 3.6 over it's life span. Having started with 5w30, then moved to 5w20 in 2014, then 0w20 in 2017. Not much changed on the engine itself except for the addition of VVT. Internal part numbers changed, but the parts are interchangeable. As in the pistons from a 2023 will work in a 2012. Lighter oil, less resistance, more efficiency, higher failure rate. The move to 5w20 saw an uptick in lifter failures. When they moved to 0w20 is when we saw a significant increase in lifter failures.
Point being. Don't read too much in to what a manufacturer recommends. As a large part of that comes down to their bottom line on cost and meeting fleet wide fuel efficiency requirements. The whole "tighter tolerances" is complete bullshtuff. They're as tight as they can be, and have been for 15+ years, without having thermal expansion interference. Go ask any machine shop or reputable engine builder.
You are correct in that tolerances have not improved much, but clearances have. This is at least partially driving the need for "thinner" oils at startup and in colder temperatures.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
I agree, the thinner cold weights make sense. It's the operating weights that are getting out of hand. Not for the 6.4, specifically, since it uses 0W40. But a lot of engine platforms are moving to 0W20, 0W10. All in the name of efficiency, at the cost of reliability. Those oils are so thin at operating temp that they lack the shear strength to prevent failures. As most of these newer engine platforms operate at higher temps. Instead of investing in technologies that would provide a cleaner, more efficient burn of fuel they're taking the easy road by increasing operating temps, and in turn increasing thermal expansion, which requires lighter oils to be able to get in to those bearing journals. Among other shady tricks, like low friction rings, lightening of rotating internals.
ramffml
ramforum
That's actually backwards? Tolerances have improved, clearances haven't. A clearance is a spec, a tolerance is how much variation from that spec you will tolerate.
Our production lines have improved in that the tolerances/precision manufacturing has improved, but there are guys on bitog who are basically saying clearances haven't changed on engines in like 30+ years because of the physics of different metals; we can't get away from the fact that iron/aluminum/copper all expand and contract at different rates, so the clearnances in an engine need to account for that.
Sherman Bird
Houston, Texas
Thanks, I figured I was reading it right. It just kind of surprised me. Where have you found that weight? I was in WM last week and thought I'd go look, but none of the brands had that.
Being that you are in Arkansas, 0W is largely unnecessary, considering the time of year it is. The first number is reference for oil flow at zero degrees. Read the owner's manual again and see if they allow for "severe" duty oil at a different weight. Seeing as how we are all in warmer weather, the first number doesn't apply.
Tulecreeper
Tulecreeper
Sthrn AZ
No, it says "Engine Oil - Mopar API Certified SAE 0W-40 Full Synthetic Engine Oil...MS-A0921. Equivalent 0W-40 oil can be used but must have API Donut trademark".
Jane S
IADR - the 6.4L recommended oil is 0w40 - the additive package is of equal imporatance to the 0w. So, it is important for th OP to use PUP 0w40.
Riccochet
This is exactly the reason why "engines are built to tighter tolerances" is mostly b.s. I say mostly because materials have improved, but enough to where clearances have really been reduced. We've had the machining capability to produce engines with precision for decades. But we still have to take in to account thermals. Thermal expansion is a b**ch. You can negate it a point with enough cooling, but then you are killing the efficiency of the engine with reduced head/combustion chamber temps.
Tulecreeper
Tulecreeper
Sthrn AZ
Thanks to everyone who had input to my original question. I've learned a couple things. So now, taking into consideration all the advice over 10 days and 7 pages, I guess in a nutshell the real question should be:
Is there an equivalent 0W-40 oil that can be used other than Pennzoil Ultra Platinum? That stuff runs $13 - $15 per quart, and although I'm not without the funds to pay $100 for 7 quarts of oil, if I could find a replacement equivalent for even 2/3 the price I'd save enough for a 30-pak of cheap-o beer. A man's got have his priorities, ya know. :happy160:
Riccochet
Over the years of owning Hemi trucks, and reading on this forum and BITOG, it's been the consensus that Hemi's like oil with high moly content. And the best 3 are Pennzoil Ultra Platinum, Red Line and Amsoil. Schaeffer's can also be tossed in there.
Unfortunately they're all over $10 a quart. Sometimes you can find those deals on the 5 quart jugs for at or just under $10/qt.
If I were going to run something other than those 4 it'd be Mobil1 Euro Spec 0W40 or Red Line Pro Series 5W40.
ramffml
ramforum
What does mobil 1 0w-40 cost in your area?
Jimmy07
Not quite 2/3 of the price, but close:
Mopar Chrysler Dodge Jeep Penzoil Ultra Platinum Full Synthetic 0W-40 7 Qts. https://a.co/d/bgR33PE
Jane S
PUP on Amazon is less than $9/qt the last time I looked.
ALSO, considering the cost of your truck - do you really want to skimp on the oil and filter?
Skip a truck wash to save $.
Jane S
I use PUP, Lubegard in oil and Mirical Mystery oil in the gas.
Try it.
ramffml
ramforum
The stuff that's called "Supercar", or "European Car" formula runs less than $10 per quart.
Yep, the euro version is what some on here are using. May want to check with @Burla or @Travis8352 as they know a lot more about this oil. It is pretty stout and is well regarded on bitog as well.
I've used it in my 5.7, worked great, no problems with it other than its down on moly and I don't mind spending a bit more on a more premium oil.
Tulecreeper
Tulecreeper
Sthrn AZ
Oh, it wouldn't bother me at all if I had to use the Pennzoil Ultra. I'm just in the process of a learning curve with the new truck.
OasisNinjaBat
