Oil
Hcamper
Iowa
So oil cap says use 5/20 oil. I pull a 35 foot TT. I go to Florida from Iowa every winter. In summer time mostly don't pull a camper. 2 or 3 times I go 200 miles pulling a camper in summer. So should I be using 5/30 or 10/30 oil or just use 5/20? 2013 Ram 5.7 2500 crew cab.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
What's the coldest temp you start your truck in?
How much does your trailer weigh? Do you pull through mountainous terrain? Do you pull your camper to Florida?
What's the hottest temp you pull your trailer in?
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
I lived in Iowa City for 3 years. Ran 5w30 redline year round pulled trailer drove in -40, idled in a blizzard for 9 hours.
No worries, I think you are better off with 5w30.
My opinion
kevcarr59
6.4L Hemi
The same question as above...
Normally 30 degrees, last Feb. it was 4 degrees...
8,000 pounds, mountains, yes, not yet but probably...
Hit 90's most of the time...
turkeybird56
Central Texas
^^^^^^^^^^^ DITTO ^^^^^^^^^^^^^
