Brakelate
- Aug 13, 2013
- 1,236
- 732
- Location
- South/Central Utah
- 2018
- 6.4 Hemi
and the times that it would help, its nothing that engaging 4wd couldnt fix.
M'eh. Maybe.
I think honestly, I would rather have a vehicle with a good, tight, LSD and some decent tires as opposed to a "4WD" vehicle with standard street tires, and no form of traction aid, like a LSD or electronic traction control device.
Everything works fine on fairly clean, level asphalt. Go try the first little dirt trail incline. The 2WD, non-LSD trucks are sitting at the bottom digging a single hole with the right rear. A 2WD truck with LSD is about ten feet up, digging two ruts. The 4WD truck with "open" diffs (no LSD, etc) is about 12 feet up, digging two opposing holes. One with the right rear, the other the left front. The truck with the 4WD and rear LSD have made it through those holes and right up to the top, just about where it really gets nasty and loose. The guy with the 4wd and front and rear lockers is sitting on top of the hill watching. If he has a Winch, he is unspooling line to help his next closest buddy up for company.
Go find a trail leading up a hill. I am serious. You can literally look up the face and see these separate locations that have become dug out obstacles.
With better tires, articulation, Hp, grit, determination or being plain nuts, will get you a little further up the hill than as described above. Not much, and not without risk of damage or breakage. But, it occasionally will occur.
Neat thing about the Power Wagon, is it's rear end that operates as a LSD, until the Lockers are engaged. That is a neat trick. Combined with good tires, low gearing, suspension that will flex and the front and rear lockers, that is what really get's it's big ass places. Similar to the Jeep Rubicon's.
I hope that little visual story helps some grasp what occurs "off highway".
Wish I could find my old GoPro. I would go make a little film showing the different levels of traction management and how it looks, and how far it will take you on the same incline, sand pit or mud hole.
(Hmmm, me thinks that is a good idea for a video that might get some views and help some folks understand. Perhaps I will look into that).
Until then, grip the wheel, grit your teeth and Pin It Boys! (and girls).
