Operation SRT blackout has begun
R/T_Fire
Pleasant Grove
Started with a set of alum SRT-10 wheels i picked up off Dubstep.
Started out by cleaning them really well, acid washed and then hit them with a 360 grit scotch bright pad.
[/IMG]
Then i hit it with a single coat so far of duplicolor etching primer. Ill sand it between coats before i start color steps. Hopefully tomorrow.
Sent from my SM-G920V using Tapatalk
R/T_Fire
R/T_Fire
Pleasant Grove
I'll be more of a fan when they are painted.... it's a crap ton of work to custom paint them instead of just shoot them black.
R/T_Fire
R/T_Fire
Pleasant Grove
Step 3 red outline.
Tomorrow i will back mask starting at the wheel lip with a 1/4 vinyl tape as a guide then run a 1/8" vinyl tape that will keep the red once i shoot them black. For now its bed time.
timmmithy
Subscribed, Im interested in the elaborate paint process.
Sent from my D6603 using Tapatalk
jknappen
Kentucky
Interested as well
R/T_Fire
R/T_Fire
Pleasant Grove
Put a layer of black on last night.... have one minor run that I need to fix so I didn't unmask and snap a shot of it... I'll fix it tonight and respray, unmask and snap a few shots
BlownGP
Houston/Baton Rouge
Doing the redline.. Going to look good.
You using a spary gun for paint?
R/T_Fire
R/T_Fire
Pleasant Grove
No, I got impatient and just got rattle cans...
I'm not all set up with air in the workshop shed yet, haven't got to plumbing the air lines from the pump house where I have the Air compressor. I have a 150' of 3/8 hose stretched through the yard to get air out to is but want more volume in the line that long for painting... I'm slacking on the project and my impatience to get things done on the projects doesn't help.... more than likely I will end up redoing them later
DavidRam
SoCal - Redondo Beach
2012 RCSB
Very cool, man! Reminds me of these... :naughty:
AFMoulton
Nuevo Mexico
Man, I may just do this to my 17" painted wheels, then get better tires! these will look sweet!
R/T_Fire
R/T_Fire
Pleasant Grove
Yep, that's all there is to see. There is literally nothing else in that picture! Lol
Now on a second look trying to not let the sweet sweet chassis distract me.... I kinda like how those Lambo wheels look...
BlownGP
Houston/Baton Rouge
Hey, the rattle can work well too. I've done it many times of engine parts, wheels brakes etc..
You need your eyes checked. Those look nothing like his wheels. lol:roflsquared::roflsquared::roflsquared::roflsquared::roflsquared:
R/T_Fire
R/T_Fire
Pleasant Grove
True, just not liking how the duplicolor nozzle is atomizing... might also be cause I was pushing the low side of the temp range.... also due to my impatience. Probably should wait till it gets back up to the 80's and not so much moisture in the air.
dakota18
