Opinions on Backup Camera Harness In the Works
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
2013 only had rear parking sensors so that's what this would add. I have the prototype on my truck right now and it works exactly like OEM.
This sounds a lot better than the Mopar option. (Speaker on the pillar).
How did you add the sensors?
Will you be doing the whole kit with harness, module & sensors? (If not, perhaps AllMoparParts can package the rest.)
Sent from my LG G4 on Tapatalk.
adrianp89
Tampa Bay, FL
Last question ... I think.
What happens if your close to something in the front and back? Like if your parallel parking?
Mpgrimm2
SC
5.7L
I could do either depending on whatever the customer wants. I created a harness to go from the 4 sensors to the factory module that mounts under the steering column. It also runs to a can line under the steering wheel. You also install the switch panel under the radio.
You should start a new thread about this, but...
How did you intake the rear bumper sensors? Replace bumper, drill holes, etc?
What does that switch look like under the radio?
C
CuylerTech
NH
2015 Big Horn Mega Cab 4x4
6.7L
I drilled my holes off of measurements I got from a truck with them. The switch replaces the panel that has the traction control and tow/haul buttons and adds the park assist turn off button.
Mpgrimm2
SC
5.7L
It would definitely help to see this as an install thread with any pictures, p/n's, etc that are involved so people can judge the install with total cost separate or with the harness.
C
CuylerTech
NH
6.7L
I dont have my truck this week until friday so it will have to wait till then. Basically it is an OEM install with my harness instead of using the mopar harness. The plugs for the parking sense module are a quite bit pricy, so this will be an $$$ install. Total im into it with the parking sense module ($80), Multiswitch panel ($100), parking sensors ($48), Harness parts cost ($100). Just as an idea of price, remember that the harness price is JUST PARTS not including my labor to build it or the cost to get it to your door.
R.L.K.
Bristol , Tn.
So total cost aprox $440 ish shipped ?
That is a bit pricy , but I think it would be worth it , I just bumped another truck squeezing into a parking spot today @ food city
Luckily the driver was still in his vehicle = no damage all is well .
@ Cuyler Tech how long would it take me a first time installer to install this kit start to finish ?
Mpgrimm2
SC
5.7L
Mopar kit is adhesive pucks that mount to the bumper and don't interface with the vehicle besides power. Our kit will wire into the factory parking assist module that mounts under the steering column, and will have the distance indicators Come up on the cluster.
Went back and re-read the add-on 2009+ Park Assist install directions...
You're right, it's worse than an aftermarket option and only adds a buzzer/speaker and the adhesive sensors with no actual tie in to the factory data/can bus. Garbage.
smoothee
St. John's, NL
I realize it's a totally different electrical system, but any factory like proximity sensor options out there for the pre 13 4th Gens?
Mpgrimm2
SC
5.7L
Ram has a Park Assist add-on system with adhesive sensors that we were just talking about for 2009+ vehicles. PN: 82211540AB @$450 parts/$770 installed. I have seen some good aftermarket add-on's with front/back sensors that would be better though.
smoothee
St. John's, NL
Yeah I seen that. But I think your description of it being garbage is pretty accurate. Was hoping CuylerTech would possibly have/know of something more along the lines of the kit he's come up with for the 13+.
Ricks Ram
If you develop a harness I would be interested. I already have the backup cam and when I checked my truck had the park assist as an optional code so that shouldn't be a problem.
R.L.K.
Bristol , Tn.
Kit will go on sale starting January 1st.
You talking about front or rear parking sensors?
I have a back up cam , it's great !
I'm interested in the front parking sensors.
Sir , do you have a projected price for front sensor kit ?
I still have the basic cluster and only the RA2 5.0. Would the front sensor have an independent speaker or would it work through the radio ?
Interested ....
adrianp89
Tampa Bay, FL
Still curious how it would work when sensing something in the front and rear at same time...
C
CuylerTech
NH
6.7L
When you go into reverse or I believe below 5 MPH forward, it turns on the parking sensors. On the evic it comes up with a image of the truck and has little circles on the front and the back that show where you are close etc.
R.L.K.
Bristol , Tn.
Would this require an upgrade to a premium cluster or will it display with the basic cluster ?
C
CuylerTech
NH
6.7L
not sure, only tried with a premium cluster.
Ricks Ram
I am thinking it would work with the standard 3.5" cluster. The Nav works in the standard cluster as well as the Homelink. I have seen Tradesman trucks with the factory Park Assist that have the standard cluster. I am not sure if it would be as detailed as the Premium cluster but I would be suprised if it didn't work.
cptwing
The Soviet State of Connecticut
2014 3500 ST DRW REG CAB
6.4l Hemi
jackblackjeet
St Louis, MO
Coworker with a '14 Laramie rear ended a car going ~25mph and he said the front park assist chimes went off right before impact but obviously going to fast to do anything about it.
moates49
