i was able to fit everything in the headlight housing, the HB dust cap barely went on but it did go on.
Regarding the cap polarity, i felt everything really only went together 1 way. you had the ability to install the cap either way, but only one way really seemed to want to stay together. I can try messing around with the various parts to see if i can find one bad one, that being said its snowing outside =)
I also noticed my HB isnt really any brighter then my LB. I read that is because the HB should be clocked at the 9 and 3 oclock position. Mine are 12 and 6. The post i found suggests drilling out the metal ring and moving the bulbs 90 degrees. I wasnt going to bother doing that yet but i am curious if you did the same thing or just let it go as is.
That's interesting because many members on here said that they installed the FluxBeam X bulbs and they definitely did NOT fit in the high beam housing.
With that said, my truck came with Duals from the factory. When I swapped over the Quads, I dont get the function of the low beam staying on when I turn on the high beam. Something about Signals from the trucks TIPM or something about adding a sales code. It really doesn't bother me because these low beam led bulbs are so damn bright when I turn in my Halogen high beams it doesn't even look like I have any headlights on lol.
If I put the opt7 FluxBeam-X bulbs into my high beam spot, when I turn on my high beams it will look exactly like my low beams so I saw no point to spend an extra $110 on high beam bulbs.
As for flipping the polarity I was trying to explain it to another member on these forums and I ended up drawing up a quick image with my phones paint program. Now don't make fun of me for how terrible it is, I was using my finger on a touch screen to try to draw straight lines lol...
^^^^ Those are the Capacitors. Notice the one end has the #1 Tag. The other end has no tag and that end goes to your truck.
If you look at the above picture, the white arrow is the normal way to hook up the adapters. study the end that goes to your truck you will notice it has notches on both sides (see arrows). These little notches are what locks the plugs together. On the one side, the notch is closest to the plugs opening (white arrow). The other side of the plug, the notch is closest to the plugs wiring (Red arrow)
This is what "reversing/flipping the polarity will do:
So flipping the polarity will reverse the power and ground wires. Your problem sounds like a bad ground. I'm guessing that one of your Adapters is backwards or all of them are. Make sure you hook all of them up with the same notch facing up. Then try flipping all of them so you use the other notch facing up.
Let me know if you need any more help with this or if the problem still persists after this. I have the FluxBeam-X in my low beams and have no bulb out warnings, no flickering and no issues. The fans are super quiet too.
Sent from hell via TapATalk
