Opticoat pro vs cQuartz pro?
Doxmia
Canada
Would be curious to hear some of your opinions on which one you preferred if you've done them both.
I had my last truck Opticoated and it worked/looked great, but curious if there's a reason I should look at cQuartz instead.
Kinetic
The performance will be very similar, however it comes down to the maintenance which is the biggest factor. Also it will be more difficult to find a Cquartez Finest dealer as there aren't near as many as Opticoat dealers.
At the end of the day it comes down to what you like the looks of more, you can't go wrong with either one. If I had to choose one it would be Cquartz for sure.
tones2SS
MA
3.3 tt
^I'm with this guy. I have Cquartz Finest on my truck. Awesome stuff.
I just learned that my usual Cquartz detailer doesn't deal with Cquartz anymore. Now, the closest one is about 75 minutes away, one way. I may have no choice but to go Opti-coat or something similar. SUCKS!!!
gixxer
SK Canada
4.7L
You could also get the cquartz or Wolfgang ceramic coating and do it yourself.
tones2SS
MA
3.3 tt
Yeah, but,.....yo have to be PERFECT at applying it. First you need to do a correct color correction and cleaning getting the oils out of the paint. Then you have to apply the coating evenly. If not, you will have levels or bumps on the clearcoat.
You can do it yourself, but I'd rather leave that to the professionals to make sure it is actually going to do it's job properly and last.
Kinetic
It's easier than you think. Yes all swirls and defects should be polished first and the oils cleaned, but when applying a coating, just make sure it's on as evenly as possible and when buffing off use two towels, the first to remove the excess coating and the second, used immediately after, to make sure there aren't any high spots left.
Doxmia
Doxmia
Canada
I might get a quote on cQuartz Finest to see the price difference between that and the Opticoat. We have one local dealer.
gixxer
SK Canada
4.7L
From what I’ve seen the Wolfgang is really easy to use.
tones2SS
MA
3.3 tt
True.
I could probably do it awesome, but I'll pay the professionals to have come out 100% perfect.
Definitely. Cquartz is an awesome coating.
I heard that as well.
Just prep the paint and get the oils out and make sure the paint is prefect before applying to make sure you're not wasting time and money. If it's not applied correctly, you're wasting both time and money, obviously.
Pull Ya
Cedar Creek, Tx
The foundation is always the most important part.
Jay
