Options for DPF removal as far as tuners go?
Mr_Nacho
Mr_Nacho
Saluda, S.C.
It only does it when the engine is lugging the trucks weight when it is creeping along in gear. It wont do it in neutral
smykowski
Pacific, MO
2010 SLT
6.7L Cummins
so when you say rattle...as in noise or vibration? if it's vibration....it's usually from the torque converter slipping a little bit, that and the drivetrain will shake when lugging under load.
Mr_Nacho
Mr_Nacho
Saluda, S.C.
I guess it would be more of a rattle. Cant be the TC because its a G56. My uncle has an 05 dually with the same trans, no rattle iirc.
smykowski
Pacific, MO
2010 SLT
6.7L Cummins
ah my bad must've missed that. I know the downpipe comes pretty close to the trans crossmember, lugging may twist everything just enough to make contact...it's a long shot but ya never know.
Stangshcky12
Oshkosh, WI
5.9 Cummins
Sounds like an aftermarket clutch to me
Most dual disc clutches are noisy an almost growl/grind when lugged
