Phil3500
The actual list pin weight of the unit is 3100 lbs, unloaded based on average. That is directly from the manufacturer specs.
So, sorry to be such a hassle.
You are correct. The dealer couldn't configure it with the 4.10 unless I switch.4.10 is only available with the dually, as I stated above, unless I missed a change for 2020 which I doubt
I appreciate your input especially given your years of experience. I was wrong on a couple of things. The dry pin weight of the 5th wheel (2020 Van Leigh Beacon 39FBB) is 3100 lbs. That's a lot better than what I originally posted. And I can't get the 4.10 axle unless I go drw.First I don't think you can get a 4.10 axle in a SRW 3500.
Second Your original post you claimed a 3800 lb. pin weight, if that is correct your short box SRW you are pricing will be over it's rated cargo capacity by the time you are all done.
A decent slider hitch will be around 200lbs, A Demco or Pull Right auto slide is in the 400-500lb range then you have passengers and other cargo to consider. If you don't put some kind of slider in you will surly crush the rear of the cab on a tight turn because of the 6'4" bed. If you are going with an Anderson at 3800lb pin you are an accident looking for a place to happen, while they do save a bunch of weight you are extremely close to it's max pin weight plus you will still be over your cargo capacity.
If you are serious about this an 8' bed dually is the only body configuration to consider. I am talking from 20 years of experience hauling a 5th wheel trailer around the United States.
Ultimately it is still your decision and wallet.
The actual list pin weight of the unit is 3500 lbs. I added 300 lbs to it to figure in some added weight due to the 5th wheel hitch.
