Outdoormans rear coil spring question.
Rwgarrison23
Salem, Va
Does the outdoorman rear coil spring sits a inch taller than the regular ram 1500?
pacofortacos
I don't think mine did, but it has been a long time since I had the stock springs on.
But if I remember correctly the rear was about at 39".
AZmtns
Southeast AZ
2012 Outdoorsman
It’s supposed to be .7 inch higher
pacofortacos
As far as I know the 0.7" higher is in the front.
Rwgarrison23
Rwgarrison23
Salem, Va
Well, I was trying to figure out which factory rear spring is the tallest and stiffer to use on my truck with a 4 inch lift kit to get that factory rake back. Level out when towing.
