Over heating problems
preston Kerry
4.7L
Hi my name is Preston,, I'm new to this and I've been having some over heating problems with my truck and I don't get it Because the radiator, water pump and thermostat has been changed...the truck also has been pressure tested....It will let me drive it about 5 to 10 miles before it will start getting over normal........Please help me with any suggestions
txbass06
NE Texas
5.9 Magnum
Are you noticing any unusual coolant loss?
Don't leave out the possibility of one of the new parts being defective out of the box. Working in parts, I've seen it happen a few times.
When it over heats, does the temp just continue to rise till it's hot or jump up all of a sudden?
- Sent from my iPhone 4 using Tapatalk
LB3711
Trumbull, CT
3.6L V6
Is all the air out of the system?
- Sent from my AT&T iPhone 4.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Welcome to the site.
As stated above those parts can be bad.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Make sure you dont overheat it, 4.7s are know for warping the heads once they get hot.
nim81
Fredericktown, MO
5.7L
welcome to RF!
thermostats are notorious for being bad out of the box. also could the thermostat be installed upside down?
truckin151
2013 sport
Air in the system, Bad radiator cap, Bad T-stat. Those would be my first 3 spots to check.
txbass06
NE Texas
5.9 Magnum
Easy and old school way to check the t-stat is to pull it out and put it in some boiling water to see if it opens by itself
