Overnight oil pressure drop, Quick Fix!
DtheBC
North Carolina
This is a big shout out to the folks on this forum. Out of the blue when going to work yesterday I noticed my oil pressure about 5 Psi lower than normal. It stayed that way even warmed up. A quick search and some reading on here and quite a few folks said change the oil filter. I did this afternoon and the oil pressure is normal again. Its weird that the night before it was normal and over night it changed. I am guessing a failed filter as theres only 2000 miles on a fluid and filter change. I have been using the Fram ultra Gold filter with good service but I am rethinking that one and gonna use WIX XP from now on. Thanks to you all!
Daw14
South Florida
I know it’s a bit late ,but do you remember what number it was that failed . Thanks Vern.
DtheBC
DtheBC
North Carolina
It was an XG10060 the gold painted filter. I have used them with No trouble for years. I cut it open and it wasnt that dirty, no metal flakes and all looked ok. It just had a problem as I am still on the same oil and the filter I put on with no issues. I dont put a lot miles on my truck. May have been a fluke, just a little disconcerting with the cost of repairs and such.
huntergreen
Marine Corps Navy Badge
Did you check the bypass valve ?
DtheBC
DtheBC
North Carolina
I did and the parts looked ok. But all that comes apart when you open the filter and if something was off kilter you couldnt tell. The anti drainback and the bypass seals were not torn. I have no Idea what happened but it had to be the filter as a new one fixed it. I have never had this happen before so no clue.
akvanden
Twin Cities
2018 1500 Bighorn
Same thing happened to me yesterday on my 2015. Was just starting a 300 mile trip and notice my oil PSI was down to about 45 while driving around 70mph (typically in low 50s). By end of trip PSI was down to 40 doing 70 mph! Was using same Fram Ultra filter you were - XG10060. Was 3,200 miles into oil change. Stopped at local Autozone and got their STP xl filter (no clue if any good) and changed out this morning. Was at 42 psi when I pulled into garage, went up to 55 once I changed and pulled out of garage. Clearly defective.
Think I'm changing to WIX from now on.
oil filter thread
the last 20-30 pages shows you might want to rethink that wix xp. yes it likely wont clog or stiffen up like paper filters do, but it also isnt very good at filtering. We just post the facts, your choice, gl. At 50 microns literally every filter traps that size 99% except wix xp.
Even worse as you see smaller size particles, it doesnt filter at all, as in near zero % effective when every other filter captures most small particles.
sandawilliams
Pueblo West, Co.
6.4 hemi
Wix let me down today. I am in upper Washington state with the camper. I needed an oil change and being in a remote area I purchased the materials 200 miles away, took them to a small town and had a local shop change the oil. The wix filter I bought could not be screwed onto the truck. Close inspection showed the factory threads were bad and filter could not be used. No more wix for me. I called the company customer service and they acted pissed off because I would bother them with such a trivial problem.
Dean2
Near Edmonton
oil filter thread
How does the factory Mopar filter do in these tests? Thanks.
Burlap
last week we finally figured out mopar filters both srt and regular are rebranded wix, so bottom of the barrel in filtering. See oil filter thread for more info/
Dean2
Near Edmonton
Thanks, but that sucks. Aren't NAPA GOLD just rebranded WIX TOO. Going to have to get some filters to take to the dealer.
Richard Kim
Houston, Texas
My go to filters were:
1. Wix XP - efficiency not great but flows like cray
2. Fram Ultra - great efficiency; oil pressure funky if you try to run it past 5K
3. Purolator BOSS - found out that 8,700 miles is the limit before you run into oil pressure issues (lost 5-10 PSI).
4. Mobil 1 - no issues whatsoever. I think this will be my go-to filter from now on!
DtheBC
DtheBC
North Carolina
I just changed out my oil and filter that started this post. I went with a wix xp but had it on before I saw burlas post so I am gonna change it out to an RP. But one change I did was try the PUP EURO 0w40/ with two cans liqumoly Mos2. Man what a difference in engine noise. My HEMI never been real loud but this made a big difference. Even piston slap is lighter. I am gonna monitor piston slap as cold weather gets here so we will see long term what happens with this oil. I had enough of the watery 5w20.
gypsy400
Mopar filter for me.. truck is still under powertrain warranty, and the Mopar filter is actually cheaper than aftermarket.
Dean2
Near Edmonton
oil filter thread
Is there a chart like this for the synthetic oil filters by K and N and the Mobil 1
I imagine there is somewhere, but I have not seen it. Of course k&n is paper and m1 is combo paper and spun glass. Both finished top 5 in gm test. However, fram ultra and royal purple finished above them, which is only one reason they are popular here. Even though k&n finished top 5 in filtering, that test was with a fresh filter, spun glass retains it's rating throughout the interval, paper goes stiff and goes to bypass, literally a rock or pebble could go through. They only tested 3 100% spun glass filters, and they finished 1,2,3, as in nothing gets through, and they only tested one combo which was the m1 and it finished 4th. So I really don't understand the argument for combo filters, you pay more then paper, but that paper can still go stiff with oil heat cycles. Mise well just buy spun glass? I think guys running combo or paper should be cutting those open in long intervals and post that in syn thread.
Arturo Rojas
