Oxidized headlights
txbass06
NE Texas
5.9 Magnum
My headlights have a yellow haze to them, big surprise for a 13 year old truck, but I've got a set of hid's coming and I want to clean them up before I get them inside. ANyone used anything that actually works fairly well, other than buying a new set of assemblies?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I have used the 3m headlight restore kit before on older stuff and works good but sometimes the haze is just to much. The 3m kit is a liquid along with different sanding disks and buffers.
OklaHemi
new age hemi
i used a kit from advance auto on my tahoe. it cleaned it up well but 7 months later it came back. and i accidentally got some on the white paint and you can see the discoloration.
txbass06
txbass06
NE Texas
5.9 Magnum
They're not too bad. I just want them clearer and ready for the hid's
Also took the liberty of removing the bug shield things over the headlights
AParrette
St Augustine, FL
1997 Pontiac Grand Prix
3.8L SUPERCHARGED
wet sand with 1500 grit sand and then polish the housings
AWE Daniel
Banned
try the 3m kit, its wet sanding with 3 different grits and then some polishing compound. Should clean you up a little
Bad Habit
Land O Lakes
Modded 4.7l
i buff mine every cpl months once you start you gotta keep up with it i use a gritty boat wax cleaner and it works really well....
ramthis9501
Oklahoma
5.2 V8
What about just regular turtle wax? I've used that before and it seems to help alot
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
the problem is that the UV coating is gone............they'll never be the same. Get new ones!
I had the same problem with my second gen lights. Used one of those kits and it worked well, but it came back a few months later.
txbass06
txbass06
NE Texas
5.9 Magnum
I just don't want the "cheap" look that most of the aftermarket lights I've seen in person have. I'd almost rather buy a new OEM set...
Plus, I like the turn signal/marker light separete from the headlight
OklaHemi
new age hemi
get the oem sport lights for that model. they are clear and have two bulbs
Deviate
St. Augustine, FL
2005 4x2
I've tried the sanding and polishing deal on our Cruiser's headlights. It helps some but does indeed come back. I have read that some people suggest sanding, polishing and then clear coating them to get them to stay clear longer. Thinking about doing it and see how it works.
txbass06
txbass06
NE Texas
5.9 Magnum
Well hid's were a no-go today...
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
what happened?
txbass06
txbass06
NE Texas
5.9 Magnum
The headlight retaining ring won't sit on to the hid because of a piece of the housing that wires are ran through. I'll probably pick up another set of rings to trim and see if I can get them to work...
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
damn the luck!
What does the trim ring look like?
