Kurtis West
I've got an 07 1500 5.7 QC 4x4.
She's got roughly 181k miles on her.
For about a year now I've had an intermittent cel for P0420.
I've done a spark plug change, ran system cleaner, reset ecm, used an infrared thermometer and live data feed to try to diagnose it.
Both infared and the LD show the cats to be operating at proper temperature.
LD shows that the 02 sensors seem to be OK. However I did notice that the B1S1 seems to sit a bit higher on voltage indicating higher fuel trim and the B1S2 seems to vary slightly more than the secondary emissions side.
On bank 1 I have a bit of oil that seeped into 2 of the plug chambers from a **** valve cover gasket. I'll be replacing the gasket shortly.
Likewise bank 1 has an exhaust manifold leak.
Is it possible it's simply a bad 02 sensor or is there a chance that the manifold leak is causing an improper AF mixture in which case is causing a 0420 fault code?
